Does the 1998 Volvo S70 support Double Din
sgowda2011
Year and Model: S70, 1998
Post by sgowda2011 »
Hey Guys, I was wondering if the Volvo s70 supported Double Din. As far as looks go, it does in my opinion. But according to crutchfield, Double Dins will not fit. I am not sure what to think about that, Are there any mods that i can do to make a double din fit in my car. I was looking at the Pioneer AVH-P3200BT, it looks cool and all but if it doesnt fit im not sure why i would spend money on it.
lienmarine
Year and Model: 1998 V70XC
Post by lienmarine »
This has been a question I've had for a while too. I've see some sites say that it does (Best Buy I think) and others (Crutchfield) say that it doesn't. My 850 had a single DIN Eclipse head unit with the little hole below it for CDs. My Talon had this same set up and it would accept a double DIN unit, so I would guess that the Volvo should too. It may be a depth issue, that's the only thing I can think of.
1996 850 N/A 5 Speed 167k SOLD
1998 V70XC 153k
-Full Stage 0, HD End Links, K&N, IPD HD TCV, Forge DP BOV, shortened wastegate actuator, IPD boost gauge, Mobil 1 oil and bevel gear, 8000k HIDs, PIAA fogs.
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I think the answer is "sort of". The OEM radios are double DIN but my understanding is that the rails need to be modified to get the aftermarket radio to fit.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You have to hacksaw or dremel those two "slots" that are down each side that guide the OEM radios.
Once done you can't go back to a stock radio though
peacock
Year and Model: S70 T5 SE 1998
Post by peacock »
Your better option is to buy a Blitz safe ipod adapter for $80 and keep the more then adequate stock set up. its less complicated cheaper and the song selection is still dont through the user interface.
1998 S70 T5 SE 214,001
1999 v70R 126,000
sgowda2011
Thanks for all your help, I also had another question but this one is about how to open up the door panels. Is there any directions i can follow to do this, i am trying to install a new speaker unit and i am in dire need of some directions.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
'98 S70 T5
2016 Chevy Cruze Premier
kringer2
Year and Model: 1999 S70 GLT 195K
Post by kringer2 »
Hate to revive this, but I had a hard time finding information.
I did have to trim the rails inside the hole a little.
I also bought a trim ring for a f-150 ford 2004-2008 to get the finished look - it did require trimming to fit. I think it looks good.
I hope this helps some of you out there!
Double Din
Double Din
larger area
larger area
MatDesign84
Year and Model: 1997,855 T5
Post by MatDesign84 »
That looks REALLY good.
Currently: 1997, 855 T5 | 1998 Subaru Legacy GT 2.5
Previous: 1997, 850 GLT | 1993, 850 GLT | 1988, BMW 325i, 1990 Volvo 240 DL
"That's good to know though in case they let loose again, but I swear if they do, I'll punch something." -jblackburn
LamboSE5
Year and Model: Empty
Post by LamboSE5 »
I would've thought there would be an "aftermarket audio" dedicated forum here, or sub-forum. I looked but maybe it's here somewhere...
I have a kenwood ddx418 double din that I wanna put in to my S70. Still need a wiring harness.
While I'm here though - ANY suggestions on a good (better) double din head unit guys? I haven't found many reviews on this ddx418 and the ones I did find weren't that favorable -- bad blutooth connectivity and stuff.
Peace.
