95 960 dtc reader led steady "on"
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
lilmikeyzz
Year and Model: 1995 960
Post by lilmikeyzz »
led for port #1 (for the trans) does not go out or flash when i plug into it, just a steady glowing light. dash arrow on steady (no flashing). seems to be in winter mode with intermittent short bursts of downshifting into a "real" gear. tried replacing W-E-S switch to no avail. can't run any tests until i get past this glitch. thanks for any help.
hollywood953
Year and Model: 960 1996
Post by hollywood953 »
have you tried unlocking the selector? There is a procedure for this on this sight and in most owners manuals. I have heard of many cars with this problem.
lilmikeyzz
not sure what you mean by "selector"? the actual gear selector? it's not locked. my primary problem is that i can't get any trans codes out of the unit. with a scan tool all i get is "communication failure". fluid level good, connectors at trans good, reverse lights good, soft clicking heard after starting and putting back in "park".
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
This is how to check the OBD unit.
960 OBD system faults..pdf
(86.79 KiB) Downloaded 127 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
lilmikeyzz
swapped out tcm - same as before. will check obd unit as described. thanks.
lilmikeyzz
problem solved: tcm had lost its ground somewhere in the harness. ran new wire from pin to ground and system went back to normal.
billofdurham
Thank you for the update.
Bill
Previously:
