See if you can diagnose this noise
fiore67
Year and Model: 93 850. 95 850
Post by fiore67 »
Hey Everyone,
Heres a good one. I have had for quite some time a noise that sounds like jingling keys coming from somewhere underneath my 850. I hear it with the windows open while hitting bumps. I did struts and rear brakes in the fall and most recently the drivers side axle. This noise was here before all these were done and continues today. Had it on the lift at my friends garage and we can't figure it out. Everything appears tight in the suspension. This has been a tough one to figure out. Any ideas on this would be great. Thanks Frank
cronce66
Year and Model: 850 Turbo, 1996
Post by cronce66 »
Perhaps this is the same noise that was on my car. I recently did pads and rotors all around, but I ended up breaking off the old parking brake shoe lining on one side taking the rear rotor off. Since I didn't have a set of parking brake shoes with me, I loosened the parking break cable quite a bit just to take tension off the shoes. Ever since, I get a jingling sound that I can hear when my window is open. Perhaps you'd want to check to see if the cable is loose on your car? Just my 2 cents....
-Lee
1996 850 Turbo - Black
V70Johnson
Post by V70Johnson »
Had a similar noise from underneath my V70. Intermittent yet annoying. Finally traced it to the front end, passenger side. The backing plate behind the brake rotor was slightly bent making contact with the rotor under certain conditions. Simple fix. Might be worth investigation.
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
Check the drop links [swaybar links] they're a common area for failure and will clunk and click as you go over bumps as will a broken caliper spring.
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
Jack Rock
Year and Model: 1998 V70R
Post by Jack Rock »
I had a similar sound in an old dodge I had. Sorry, only 3 weeks volvo experience. Anyway, the radiator was rotten and the fins were coming off bit by bit, getting thrown by the fan onto the engine, under the vehicle and hitting heat shrouds creating a 'key jingle' sound. No kidding.
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
If this were on a '55 or '56 Chevy, I'd say it's a hanger in your exhaust system. The resonant frequencies of combustion caused the "tinkling". Most of them did that. Maybe worth checking.
fiore67
Post by fiore67 »
I think i've figured out the jingling noise. The u shaped piece that fits on the a-arm that works as the bump stop. Both sides are loose that you can tap it with your finger and BAM......jingle bells. Amazing !!
