2003 S60 AWD, 97,000 miles.
Passenger side low beam went out, I replaced both bulbs but low beams won't come on for either side. Get the lo beam failure message. Checked all the fuses in the engine compartment and passenger compartment. Hi beams work. Fog lights work. Checked the fuse on light switch....
Is there a relay or ballast? There is no power to the harness. Used a new tester and tested the tester before and after to be sure.
I can't find this situation in previous posts and am stumped....
2003 S60 Low Beam Failure
billr99
- Year and Model: 2002 V70XC
Check the low beam shunt on the panel in the drivers side foot well. Although rare,they have been known to short out.
Cheers,
Bill
Cheers,
Bill
'05 XC70 (Lava Sand)-235K kms to-date
'02 V70XC (Ash Gray)-375K kms to-date
And a whole tonne of other Euro stuff (Volvo (8), VW (6), MB (1), Audi (3), BMW (2), SAAB (5), Land Rover (4), Porsche (2), Opel (1), MG (1), Mini (2), Sunbeam (1))
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 80 times
- Been thanked: 71 times
Hello billr99, What does the shunt look like? I assume it resembles a relay (plastic box plugged into a panel). Thanks. Kira
billr99
Actually it looks like a small card with 4 spade lugs sticking out of it. There are 2 or 3 in the relay panel. This link (http://www.xenonvalot.com/xenonfixvolvo.html) shows picture of the culprit.
Cheers,
Bill
Cheers,
Bill
sjr2531
- Year and Model: 1998 saffron V70R
The low beam failure associated with the HID conversions that is mentioned on hear is an easy fix. the prior post with the link http://www.xenonvalot.com/xenonfixvolvo.html is a spot on, honest fix to this problem. I was hesitant about drilling a 2mm hole in the relay but it really fixed that annoying message indicator.
2002 s60 T5 manual 98,000 miles
(R.I.P 12-26-2010 112,000 miles)
1998 Saffron V70 R 109,000 miles
"My Precious"
"My Precious"
- 11 Replies
- 8654 Views
Last post by ggleavitt
- 19 Replies
- 7772 Views
Last post by cn90
- 622 Views
Last post by osteovolvo
- 3412 Views
Last post by THAI UNG
- 28418 Views
Last post by karisa60
