Just behind the foglight grille.
Mine is still plugged in where it's supposed to be, yet shows temperatures of ~100 when it's 80 outside after I just start the car. I just figured it's cause my car is dark blue and gets HOT in the summer. It worked fine a few summers ago and fine in the winter.
It's only like a $30 part anyway.
Re: S70 Ambient Temperature Sensor Fix
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
I notice the temperature readout on the dashboard is about 20 degrees higher than outside and it seems to drop when the car is moving. I cannot find the sensor so it would be great if someone could point me to its location so I can check to see if it is touching something or the air flow is blocked.
Is this problem normally corrected by replacing the sensor?
I would appreciate pointers and pictures if you have.
Thanks in advance for your help.
JRL
- Year and Model: Several
- Been thanked: 16 times
It always adds some temp while not driving.
If it goes back to the correct temp in 2-3 minutes of driving, don't worry about it.
You all DO know that the 8/70 temp gauge reads 3-4 degrees too high?
They ALL DO
They ALL DO
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
It will read considerably higher if it isn't mounted properly though. Look near the fog lights on both sides of the car for the sensors , and when you find them, you should also be able to find the holes they are supposed to plug into on the plastic shield covering the underside of the front part of the car.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
It just started fluctuating in the last month or so. It climbs up to a high point, drops down by about 10-15 when the car in moving. As soon as the speed slows down in traffic, the temperature starts climbing in steps of 2-3 degrees up to the previous high. It looks like it is related to air flow or a defective sensor.
I tried looking for the part that looks like the replacement (online picture) but I could not find it.
Does anyone have picture of where it is? I would like to avoid getting a manual just for the the location of the sensor.
FlyingVolvo
Again, look at the front of your car. Get on the ground and look underneath where the fog lights are. Near or behind the plastic shield that covers the radiator/intercooler, you should be able to find the sensors dangling somewhere. Obviously it is related to airflow, since if they are mounted too close/improperly to the radiator area, it will get all that heat soak. When you speed up, the air is able to cool it off, showing you the lower reading.
I've never seen anyone talk about these things being defective. All that matters is their placement. And even when they are perfect, they do tend to read a little high.
2023 V60 T8 PE
2023 V60 T8 PE
jblackburn
Whoops. Well, I messed up the order, but look above. I merged a picture of the one I replied with to your response to an earlier post.
'98 S70 T5
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
There's two of them? Seems odd to have a 'backup' device on a car - I'd rather have a backup timing belt!ecbsykes wrote: Look near the fog lights on both sides of the car for the sensors , and when you find them, you should also be able to find the holes they are supposed to plug into on the plastic shield covering the underside of the front part of the car.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
iravat1234
- Year and Model: s70 1999
HI:
I am a 60+ female. The sensor is wild and it shows a farenheit temp of 120 sometimes. But I know it is inaccurate. why bother to change. (It does scare my passengers, but) ndc1943 at gmail
- 842 Views
Last post by Webpirate
- 653 Views
Last post by jreed
- 1499 Views
- 844 Views
Last post by darrylrobert
- 1150 Views
Last post by woodysca
