A/C clutch shim procedure for S60 - 2002 S60 2.4T AWD
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
This topic is in the MVS Volvo Repair Database » A/C clutch shim procedure for S60
kdaide
Volvo Repair Database A/C clutch shim procedure for S60 - 2002 S60 2.4T AWD
Post by kdaide »
I've confirmed that my A/C clutch is not engaging properly and that it could be because of wear to the clutch plate . I've read several posts about shimming the clutch plate so that the gap is return to within spec. I've seen instructions posted for other Volvo's but not for the S60. Does someone have instructions on how to do this for the S60, or at least instructions on how to remove the A/C clutch pulley.
My garage and the Volvo dealer will not perform this work. Their solution is to spend >$1,000 to replace the compressor unit.
Thanks, Kevin
2002 S60 2.4T AWD 220,000kms
Kevin
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
instructions for the 850 or S/V70 should be the same as the S60
JDS60R
Been thanked: 3 times
Post by JDS60R »
Specs
2002 S60 AC shim spec adjust.pdf
(150.28 KiB) Downloaded 7730 times
Retired
kdaide
Post by kdaide »
All-
I failed in my attempt to reshim the AC clutch. I spent all day and could not get the clutch off. It looks like i'll have to bite the bullet and replace the compressor.
FCPGroton only offers a compressor made by "Air Products" Does anyone know how this brand compares to the OEM? Any recommendations
Thanks, Kevin
2002 S60 2.4T 220,000kms
Kevin
JDS60R
Post by JDS60R »
Hi Kevin,
What happened??
Problems with the bolt or holding the clutch?
Sorry I have no info on the brand you said.
Best Wishes,
John
Retired
JDS60R
Post by JDS60R »
Here are the instructions in case you need to replace it.
I had an Eldorado in the shop for a new magnetic clutch yesterday. It turned into a nightmare and I ended up replacing the compressor as well. The Volvo S60 is lovely to work on compared to an Eldorado with a Northstar.
02 s60 ac compressor oil volume 2.3oz.pdf
(55.22 KiB) Downloaded 1254 times
02 s60 AC compressor replacement.pdf
(332.82 KiB) Downloaded 1758 times
02 S60 AC torque values.pdf
(26.41 KiB) Downloaded 1198 times
Retired
darkcountry
Year and Model: S60 2003
Post by darkcountry »
a little confused on the compressor oil volume...if i put in a new compressor do i put in 2.3 oz of oil into the compressor? i read on another forum that you need to put in 4.2 oz... any help is appreciated!
JDS60R
Post by JDS60R »
Yes 2.3 oz if you replace the compressor. Some remans and new come with some oil already in it. Usually I see 1.5 oz in a reman so I add the remainder. The compressor should have a spec sheet attached that will tell you how much is in it. If not make sure you know before ordering.
If you cant get that info just drain the oil out of the compressor and replace with 2.3 oz before install. Then pull a vacuum and charge with the right amount of refrigerant.
Retired
C@lvin
Been thanked: 2 times
Post by C@lvin »
kdaide wrote:I've confirmed that my A/C clutch is not engaging properly and that it could be because of wear to the clutch plate . I've read several posts about shimming the clutch plate so that the gap is return to within spec. I've seen instructions posted for other Volvo's but not for the S60. Does someone have instructions on how to do this for the S60, or at least instructions on how to remove the A/C clutch pulley.
Kevin, why don't you try the "gread clip" fix? At this point, what have you got to lose. It should only take you 15-20 minutes and won't cost you anything at all. I did this successfuly with both S70 and V70 a couple of years ago. I don't know for certain but I expect your 02 compressor is the same as my 00 V70.
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
malindv
Year and Model: s40 2007
Post by malindv »
Is there instructions for shiming the clutch for S40?
