Clutch problem
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
LaRy
Clutch problem
Post by LaRy »
I have got problems with my clutch. It is a Volvo 740 from 1985. Sometimes it does not open as it should, so it is difficult to get in the first gear and reverse when the car is not moving. Especially the reverse sounds terrible. The clutch is working good most of the days, but some days....... I have checked the wire from the pedal, and it is correctly adjusted with 1-3 mm play. I do not feel any difference in the pedal when it is good or having a bad day.
Can the splines for the friction disk be "stocked" on the primary gearbox shaft, because lack of grease? Could it be something else?
Volvord
Post by Volvord »
Yes, it sounds like the clutch disk is sticking on the input shaft. This can happen usually from a mixture of transmission oil and clutch dust which forms a sticky paste inside the bellhousing and on the input shaft. No real good fix without pulling the trany and when you do all that work you might as well replace the clutch.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
