03XC70 HID headlights added: fix msg: low beam bulb failure
This topic is in the MVS Volvo Repair Database » Low Beam Bulb Failure Triggered by Aftermarket Xenons
98v70GLT
Post by 98v70GLT »
To those that have the message 'low beam bulb failure' (this from memory) after installing HID headlights with a ballast.
I bought a XC70 2003 to replace the 98V70 which was bought by my friends wife and still going strong. It shows you that picking your login could be subject to change, never thought that I would 'move up'. For those interested: We like the 03, gets better gas mileage than the 98 which got 25 MPG, the XC70 gets 26 give or take! I can't believe it and of course love it!
When I purchased the car the previous owner just put Xenon headlights in this car which has the ballasts to increase the Voltage for the light bulbs. I couldn't get passed the warning light, my wife wasn't too worried about it.
The fix I came up with is to put a minimal Watt light bulb parallel in the 12V supply to the ballast. I tried some different light bulbs and it works with the following parts I picked up at Auto-zone:
Sylvania: 194 LL
License Sidemarker Socket: 85814
Just in case:
Parallel: Add one side of the Side Marker Socket to the Positive side and the other side to the Negative side of the supply line to the ballast. All we are doing is fooling the diagnostics of the car, make it think all is well.
Hope it works for those that have the same problem.
It has been A OK since this 'addition' :idea:
PS I tried some resistors as well but didn't find the right setup, reading some after market stuff it seems that they sell a resistor that is like 2A which would mean 24W, defeats the added benefit of less power consumption. The 194 LL are low light, sorry no listing of Wattage.
Head lights2.JPG (63.14 KiB) Viewed 5810 times
Head lights3.JPG (61.32 KiB) Viewed 5810 times
What you have to do, it tickles me and it works!
Head lights.JPG (67.88 KiB) Viewed 5810 times
billr99
Year and Model: 2002 V70XC
Post by billr99 »
Man, that's a fair amount of work. Try this http://www.xenonvalot.com/xenonfixvolvo.html instead.
Cheers,
Bill
'05 XC70 (Lava Sand)-235K kms to-date
'02 V70XC (Ash Gray)-375K kms to-date
And a whole tonne of other Euro stuff (Volvo (8), VW (6), MB (1), Audi (3), BMW (2), SAAB (5), Land Rover (4), Porsche (2), Opel (1), MG (1), Mini (2), Sunbeam (1))
rmojica
Year and Model: S80 2001
Post by rmojica »
i just added h7 load resistors and solved the problem
shiloh51933
Year and Model: 04 XC70/'98 V70XC
Has thanked: 28 times
Been thanked: 17 times
Post by shiloh51933 »
rmojica wrote:i just added h7 load resistors and solved the problem
Do you mean aftermarket xenon or the factory Volvo xenon headlights? Our '04xc70 came with xenon headlights, the headlights are programmed into the ECU. I see what you did, that looks ghetto under the hood like that but to each there own. Your try to grip the ECU into thinking there's the proper amount of amperage/resistance.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
