Hey gang,
For the three years I have owned my beloved S70 the air conditioning has randomly made very loud squealing like it was releasing pressure or something from a valve. I have never been 100% happy with how my car idles with the A/C on, when it is not screaming at high pitch it is making tiny little noises that I can't really describe.
What is happening with the high pitched squeal and how do I remedy it, I have never seen any other car do this. A/C works great apart from the occasional racket described.
Thanks,
- Jesse
Embarrassing A/C noises
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
igel513
- Year and Model: 2003 S60 T5
- Has thanked: 1 time
Possible causes could be bad alternator bearing, hardened drive belts. Those components can cause those squealling sound. Also check the slack on those drive belts, if they're too tight or no slack, the belts could squeal.
xjflexer
- Year and Model: '96 850 R Wagon
I would say that if this noise only happens with the A/C on, it could quite possibly be a bad bearing in the compressor. BUT, the is a possibility that your belt is old and loose, and the extra strain from the compressor being on can cause some slippage if the belt cannot keep the compressor spinning at speed with all of the other accessories it's driving. Those are the first things I would look at.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Or its a bad orifice tube. See if you can pinpoint where the noise is coming from.
'98 S70 T5
2016 Chevy Cruze Premier
IVIUSTANG
It isn't the belt I changed that and checked the tensioner before I went on my trip; it simply doesn't sound like a belt either. What is this orifice tube you speak of?
It kind of sounds like high pitched feedback from a microphone. It starts out high and then gets quieter and quieter until it fades away.
- Jesse
- Jesse
jblackburn
And it would make exactly that noise you describe!
The highlighted part right here, "expansion valve" is also called the orifice tube.
It's right in front of the receiver/dryer. The part itself is cheap and easy to fix, unfortunately the whole AC system has to be evacuated & recharged to do it.
'98 S70 T5
IVIUSTANG
Thanks, I'll give that a look this afternoon; how is it diagnosed?
- Jesse
- Jesse
jblackburn
Mainly just the noise it makes. If your AC lets out a squeal after the car is shut off, or while it is charging up for the first time in the mornings, that's what causes it as the pressure in the system is equalizing. There is another one in this AC system somewhere, but I can't tell from the diagram where it is. Listen near the dryer (the metal canister at the front, right side of the engine) and see if you can pinpoint the noise to that area.
'98 S70 T5
My 99 C70 does this too. It's a high-pitched whine that builds and drifts away when the AC is running. It usually makes its last gasp a short time after the engine's shut off. It's definitely annoying and potentially embarassing!
The mechanic said it was the expansion valve. At the time, I was unemployed, and since everything was working fine (air blowing cold), we left it. As jablackburn says, it's an easy fix, except for the evacuation/recharge part.
IVIUSTANG
Perfect, I will replace it!
- Jesse
- Jesse
