the canister purge valve swithing on/off rapidly. the purge valve works, and the wires have 13.8 v power. I think it's the connection failure.
I'm having trouble finding a connector p/n 6849784 or p/n 91480672.
So I just ignore the valve, and hooked up the two tubes directly. It works well for now. Is there going to be any problem in the future?
by the way, what the normal purge valve's action like? thanks
purge valve
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
It will open at higher RPM or cruising speed to let the fuel vapors burn off/increase fuel efficiency slightly. It shuts at low RPM/idle to keep the engine from bogging. It shouldn't, as you describe, open and shut rapidly.by the way, what the normal purge valve's action like? thanks
'98 S70 T5
2016 Chevy Cruze Premier
