Strange ticking noise.
The New XC60 is Here -- Here's Our Take
- Has thanked: 2856 times
- Been thanked: 1332 times
"STS-107 - May God bless their souls, and welcome them home." -- agreed. I wish the best for their families and kids, especially. My hat's off to the brave men and women on that mission.
As far as our mundane, earthly concerns go, I believe the ticking you hear may be the injectors. The 850 is notorious for noisy injectors causing their owners to worry about tapping valves - the sound is very similar. I hear the same thing whenever I open my hood and my engine is running. Mine is not intermittant however.
Not all engines are the same, so you may want to use a stethoscope to make sure that's where the noise is coming from.
Matthew
Matthew
No, ticking injectors is normal.
850 r
Hi
i have a tapping noise coming from my 850 R on tick over when hot and cold the tap comes and goes and if you rev the car the noise stops at over 1000 rpm i have changed oil and added oil aditve changed cam belt and tensioner and idle pully also took power steering belt of and still have noise.
Might it be the crank pulley ???
Or what is it ??????????
Please help
Please help
csbrianp
If the noise just started one day, chances are it's not your injectors. Your engine might just need a good cleaning. The 850 turbo that I bought, lost all of it's compression, because of sticking lifters. It too had tapping sound coming from under the hood.
Brian
Brian
Volvoxlr8rs
- Year and Model:
Hey 850 R I have a 98 S70GLT doing the same thing it seems. Do you notice it when you pull up hill more than on flat ground and when first accelerating. I have not been able to figure mine out yet. I will keep yall updated
youngsinauburn
- Year and Model:
I was having the same problem with my 99 s70 and I have started my first cylce of engine treatment from http://www.auto-rx.com/index.html and I can already tell a huge difference.
- Has thanked: 17 times
- Been thanked: 35 times
Hey AutoRx user, please make sure and post how your treatment is doing in the AutoRx thread going on at the top of this forum.
- 1050 Views
Last post by bluebossa
- 3901 Views
Last post by Klausc
- 993 Views
Last post by darrylrobert
- 1007 Views
- 16 Replies
- 2020 Views
Last post by Camaro737
