Cruise control not working
2012 Volvo XC70 Trim Level Comparisons
1pacificson
- Year and Model: 850 1995
The cruise control on my 1995 850 sedan is not working. Can anyone offer any help? Thank you.
I found diagram on line. there is housing that engages at the break peddle arm. you will need to take the knee bolster loose easy to do to have good visability. there is a plunger and you need to turn it to engage the metal arm
BUT first take loose the plastic vacume line and the power switch clip. that way you can turn the housing clock wise or counter clock wise in the housing depending. It worked for me. good luck
uncledave11
- Year and Model: 2011 Xc70
some models have an "extra" brake light switch that can og open and fail. you might want to start these fist as I had a fit finding this one unyil i got that info from a volvo tech. Good luck!
Dave
Dave
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The two most common failure points are the vacuum line to the cruise control pump under the battery tray, and the brake switch as stated. Other than that, sometimes the turn signal lever goes bad or the cruise control relay, but those would be last on my list to troubleshoot.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
On a '99 you don't have a cruise control pump. The cruise control is operated through the ETM. If it's flaking out like many are, it probably won't work.
'98 S70 T5
- 5301 Views
Last post by THeOldMan
- 713 Views
Last post by howardc64
- 32 Replies
- 9934 Views
Last post by zhenya
- 726 Views
Last post by Denwiley
- 1269 Views
Last post by RickHaleParker
