air conditioner does not blow. 1999 2.9 non-turbo
discoveryeagles
Year and Model: s80 2.9 1999
Post by discoveryeagles »
I have a 1999 2.9 liter engine. My a/c was recently recharged with freon. Everything was going well. The fan suddenly stopped blowing. Therefore my defrost,my air conditioner nor my heater is blowing. Asked around and was told that my blower may be out. Wanted to know if anyone else has had this problem and if so what did you do and did you have to replace the fan when you replaced the blower?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Have you checked the fuse, #26 in the passenger compartment fuse box?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
discoveryeagles
The fuse is fine. I can hear the blower trying to run when I turn the fan on. I know power is there. My fuse box is on the drivers side, but I did locate the panel to gain access to the motor behind the glove box. Thank you for your input.
billofdurham
Has a foreign body dropped in to the fan causing it to jam? It has been known.
Bill.
Previously:
discoveryeagles
The blower motor resister was bad. I have having it replaced. I also had the antifreeze leaking into the drivers floor board ; discovered that my heater coil had a hole in it. I am having it replaced. Thank you for your help.
stevick
Post by stevick »
My blower resistor ("power unit") just went out too. Were you able to find a reasonably priced one somewhere? Going price seems to be $90 (ebay) to $150 (Autozone) - way out of line for such a simple part. Can anyone recommend a good source for a used one? Thanks...
2000 S80 2.9
297K (gonna make 300K!)
dcarlson12
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by dcarlson12 »
Regarding your heater core, did you actually find/discover the hole in the core yourself? Or were you told there was a leak in it? The reason I ask is that leaks have been known to occur from I believe it is hardened 'o'rings in the connections to the heater core. Hate to see you replace the core and then find it was just a leak at the connections.
