Should I replace my water pump?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
DavidD
Year and Model: S60, 2001
Post by DavidD »
I am looking for some advice. I have a 2001 S60 T5 with 100K miles. I am going to have the timing belt replaced at the next service and am getting conflicting advice regarding the water pump. I use both the dealership and a highly regarded private shop for service. The private shop recommends replacing the water pump along with the timing belt, the dealership does not.
Does anyone have an opinion or experience with this?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
It's cheap insurance. At 100K, the pump is probably still perfectly fine. But if the coolant in the car has never been flushed/changed in its life, there's likely some corrosion on the blades that will cause it to fall apart before the next change at the 200K milestone. At 140K when mine was changed, the water pump still looked like it was in good shape, so I'll be holding out til 200-210 on it.
'98 S70 T5
2016 Chevy Cruze Premier
JDS60R
Been thanked: 3 times
Post by JDS60R »
Change it. No question about it - Change it.
Any pump bearing that has given you 100K of service is well due for a change. The new timing belt and tesioner will put a different level of tension on the waterpump that it has not experienced since new. Many of the pumps that do fail- fail shortly after replacing the tensioner and belt. Do not risk it. Change the pump.
Retired
anthonyhicks
Year and Model: s60 2004
Post by anthonyhicks »
my s60 hit 105k miles.water pump failed and warped my head. Costs to repair over $1,000
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
At that sort of mileage you would have to be looking long and deep for reasons NOT TO REPLACE.
priapism
Year and Model: 01 S60
Post by priapism »
Timing belt / water pump go together like peas / carrots and peanut butter / jelly. We pronounce the two items as a single word: timingbeltwaterpump.
Titan LE : S60 2.4t : 91 325i : Spec E30 #33
RaymanSean
Year and Model: V70 XC, 2001
Post by RaymanSean »
The prudent practice is to replace the pump with the timing belt. However, you are warned that replacing the pump does not guarantee you 100K with out failure. The new pump just reduces your chances failure.
