turbo removal xc or AWD.. reaching the lowr driver nut?
tyring to remove a turbo this weekend. have everyline line and fitting off BUT the last nut on the lower drivers side of the turbo. the nut is the lower left (driverside) one between the turbo flange and the exhaust manifold. 13mm nit. how do you get a sockect, wrench, crows foot, etc on this thing? any help would by greatly appreciated. thanks
98 V70R AWD
98 V70 T5 5 speed
98 V70 T5 5 speed
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
I spent hours trying to get that same nut out. It's at the most impossible angle. If it weren't for the bevel gear you could get to it.
Never did get it out. I had to pull the bevel gear anyway, so that's how I got to it.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Matty Moo
Well, you have to remove the passenger side axle, then pull all the bolts around the gear. I haven't put it back together yet since I pulled the engine.
I'd say you're looking at 2-3 hours at least if you've never done it before.
2000 s70 GLT
2014 Ram
Matty Moo
I'm going to remember this for future reference. I spent a good 2 hours and every possible angle to get to that one nut.
2000 s70 GLT
2014 Ram
- 573 Views
Last post by jonesg
- 900 Views
Last post by zombielinux
