Brake fluid leaking
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
This topic is in the MVS Volvo Repair Database » 850, V70 and S70 Shock Change Checklist
kaverryan
Year and Model: 2006 S60 T5 manual
Brake fluid leaking
Post by kaverryan »
A new leak on my '06 S60 T5 manual (71,000 miles). I have determined it is brake fluid. Below is a photo of the point that leaks. It's from some type of vent hole between the engine and the trans. I can only think it's coming from above and just showing up there. Where would you look first?
Some time ago a warning light came on that said "Anti Skid Service Required" but the went out and has not come back. I'm now getting a low brake fluid warning for obvious reasons.
JDS60R
Been thanked: 3 times
Post by JDS60R »
Usually clutch slave cylinder leak.
Check if master cylinder level is going down to assure that its the slave.
If so plan for $2000 repair bill and 3-7 days without car .
If you have a warranty bring the car immediately. The clutch plate will be ruined by the fluid.
Retired
