Snow is on its way! Snow tires and sizes
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Esnoyer
Year and Model: V70 03
Post by Esnoyer »
I have 4 low k 215 55 16 tires mounted on steel rims with caps from a previous Volvo, My current V70 uses 205 55 16..
By my calulation 60 k would become 62k if I use the larger size,other than that could these tires cause any other problems?
The Volve dealer says not to do it.. Better to buy another set of Geslivads..
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
http://www.miata.net/garage/tirecalc.html
You should be just fine as long as all the tires match in tread
Odd size, what did they come off of?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2664 times
Been thanked: 1256 times
Post by matthew1 »
I get 61.04 kph.
According to this, 215's are 79.517 circumference, in inches, vs. 78.156. Percent larger = 0.98. That is really insignificant regarding gear ratios. For speed, just use your brain to add a kph. Our speedometers aren't accurate to that degree anyway.
A bigger worry might be rubbing due to tire width: 25.311 vs 24.878 (inches). Just go full-lock when turning the wheel, then back off a touch. I've been doing it for 10 years with my 850.
Also -> Amazon link
Esnoyer
Post by Esnoyer »
JRL wrote:http://www.miata.net/garage/tirecalc.html
They came off of a Volvo XC
