Question not answered: chip to 1+ bar of boost fuel cut out?
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
NiksT5
Year and Model: 1994 850 Turbo
Post by NiksT5 »
So my question (after hours of searching) is are there any chips out there or ecu flashes or whatever that actually take out the 1 bar of boost fuel cut out? I know that there are quite a few guys out there running high boost, maybe someone can help me out here.
Reason: Edited title for clarity.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Please re-phrase the question that it makes sense!
NiksT5
Post by NiksT5 »
Do any of the ecu Chips or reflashes actually take out the factory over boost limiter. In other words can you run more that 15psi?
JRL
Post by JRL »
Of course
My (IPD) chipped Gen 1s ran at about 17 with spikes to 18 or so
flyfishing3
Post by flyfishing3 »
sure, i'm set up for 1.2 bar, had the red line raised, the fuel cut off raised, the torque limiter removed in 1st and 2nd.
you can do anything you want if you get to the right people.
phenom9579
Year and Model: 1998 S70 T5
Post by phenom9579 »
All ECU flashes that I know of remove the factory fuel cut off. Haven't heard of one that doesn't.
