Timing Belt Tools
Timing Belt Tools
Replacing timing belt, water pump and other parts on my 2002 S60 AWD 2.4 turbo. I need to know what the cam lockdown tools are and a part number and place to order them from. I tried ZDMAC and IPD but no luck without a part number. HELP!
ed7
- Year and Model: V70XC 2005, 2001
- Has thanked: 2 times
You don't need special tools, that's what the timing marks are for. Align the marks at the beginning.
A good mirror helps when working on top to check the cam marks.
Read all the good info around here!
ED7
ED7
I am awaiting the CD with the detailed info and will attempt to do. In the meantime I will continue to research this forum for any tips. I was an "A" tech for many years and have also done this on a number of Audi's, but this sounds like it may be a bit trickier the first time around by what I have read.
ed7
Volvospeed has some good info. This is what I used when I first got my car.
Pictures are everything, and the words help too.
http://volvospeed.com/Repair/timingbelt.php this the early engines.
http://www.volvoxc.com/resources/how-to ... ement2.pdf this is the later engines.
There is one difference, the cam marks are at 12:00 on our later models.
Take your time, the hard part would be the water pump.
Ed7
Ed7
Retired MVS Contributor
You don't REALLY need special tools, but IPD's P/N T850CT cam lock is handy because the cams have a tendency to seek the low point on the lobes once you remove the belt...It might move off the mark without you spotting it as you try to put the new belt on...Then you have to remove the belt and start over...randyman wrote:Replacing timing belt, water pump and other parts on my 2002 S60 AWD 2.4 turbo. I need to know what the cam lockdown tools are and a part number and place to order them from. I tried ZDMAC and IPD but no luck without a part number. HELP!
- Has thanked: 17 times
- Been thanked: 35 times
Funny, my mechanic just did this with my wife's '04 V70- didn't use any cam lock tool and the lobes didn't move- he said that was pretty rare, actually but he's done hundreds of these- all said, it took him about 45 mins to finish the jobs (didn't do the water pump- it wasn't leaking- so hopefully we won't have to get back in there anytime soon).
