upper engine mount
MikeLass
upper engine mount
Post by MikeLass »
I have a 1995 850 GLT that needs a new upper engine mount. I'm told that an aftermarket POLY bushing will last much longer than the OEM part. I'm looking for a source for the POLY bushing.
-Lassiter
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
You can find them at ipd, link's on my Main page.
I've heard they last longer but transmit more vibrations to the cabin. Keep in mind that's someone's opnion that I'm repeating -- I've not replaced mine yet. If you call ipd you might want to ask the rep if he's heard similar reports.
If you find anything out or replace with a poly., repost back here your experiences :)
Thanks!
matthew1
Site Admin
Post by matthew1 »
Oops, link's not there... try http://www.easternaerospace.com/automotive/maintenance/
$25 US
MikeLass
Post by MikeLass »
Thank you for the referal to IPD. I have installed the new poly bushing - no problem. The part came with an instruction sheet that was very helpful. The factory bushing is pressed in place and has to be removed through the innovative use of a hacksaw. The new bushing works perfectly and should last a long time.
:D
-Lassiter
MJJ
Post by MJJ »
Did you find that the poly mount resulted in more vibration?
MikeLass
Post by MikeLass »
No problem with any vibration. I highly recommend the poly bushing. My mechanic quoted me $150 to install his poly bushing. I bought one on-line from IPD for $31 (including shipping) and it took hand tools and 20 minutes to install.
-Lassiter
matthew1
Site Admin
Post by matthew1 »
Mike,
Thanks for posting the conclusion. In a grand sense, it shows that if one is even reasonably familiar with cars, you can save a bundle of dough with our 850s, and Volvos in general, by doing the little-medium stuff your own self.
If it were not this way, I would not be able to afford my Volvo.
Matthew
MJJ
Post by MJJ »
OK! I'm in! I'll take 3!
Thanks, Mike.
