Replacement of sideview mirror light Topic is solved
new99S80owner
Post by new99S80owner »
I noticed that my driver's side review mirror courtesy light is burnt out. I want to replace the bulb, but can not figure out how to get to the bulb under the mirror. Any suggestions? :roll:
AR
Post by AR »
Hi
I assume you mean the drivers door mirror. The light is in a little plastic box in the bottom of the mirror unit. This little box pops out by pushing a tab 'in' on the outer edge of the light box. The tab can be prized with a small screwdriver accessed below the bottom of the glass but inside the mirror housing. Hope this helps.
Guest
Post by Guest »
Thanks for the info, AR. Good to know that you don't have to remove the whole mirror assembly.
Eli
