2004 XC70 Sunroof Rattle
The sunroof on my car rattles when driving on rough roads. It doesn't leak but the rattle is a little annoying. Anyone have this happen? Known fixes? Thanks!
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
The sunroof in my XC90 also rattles over bumpy roads! I would love to know if that is "normal" (which I suspect it is) or something I should worry about. Does anybody know? Thanks!
2004 XC90 AWD T6
2002 Saab 9-3 SE
1978 MGB
2002 Saab 9-3 SE
1978 MGB
JRL
- Year and Model: Several
- Been thanked: 16 times
You mean the COVER is rattling, correct?
ctrobk
- Year and Model: V70 2003
I had the same problem on my '03 v70 base.
I was able to tighten the torx screws. Raise sunroof to the vent position. then carefully pull back/slide the black accordian looking material. There are two torx bit screws there, mine were loose. Be careful it is extremely easy to over tighten and strip them. I had to do this on both sides.
I will check into that and see if those screws are loose.
JRL, no, not the cover, the glass and supporting mechanisms.
2004 XC70
