Hey All wise and knowing ones !
any clues on finding a diagram for the evap system? got a code that I had a leak (Large ) in the system. got a ck. eng. lt. can clear but comes back after a while
98 V70 135K
thanks
Mike
evap system diagram
thecheat
- Year and Model: 1996 850 Turbo Wagon
Check your evap purge valve according to my how-to and either fix or replace it.
https://www.matthewsvolvosite.com/forums ... =1&t=31691
jmmxc
- Year and Model: Volvo 850, 1996
Hi lowufo777
Take a reading at my post: "Looking for the Cure for P0455, Trouble Code "
I am having the same problem as yours with my 850 GLT, 1996.
If the V70 engine is the same as an 850 in terms of the EVAP system, perhaps you can use the attached pdf files here in.
I have not been able to solve my problem yet.
I replaced the purge valve over the week end. I reset the light but the check engine light returned after 10 miles drive.
Looking at the parts listing attached, so far, I have replaced the intake hose and clamp (#14, #15). Purge Valve(#11), the elbow (#6). The long hose to the canister is fine. So far, no success. Problem seems to be further down the vac lines going to the gas pump and tank. I need to check #4 and #7a as well. I have not verified that yet.
Hope you can use the diagrams for your car. Keep posting.
jmmxc
jmmxc
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I had this same problem on my '97 855 GLT and it turned out to be the rubber connecting hoses on the roll - over valve located near the fuel filter at the back of the car. The hoses had been eaten through by a squirrel or other critter.
You want to look these up by part number - text descriptions are notoriously inaccurate.Vixvolvo wrote: 12 Jul 2019, 16:57 the hose in the diagram #5 on my volvo is needing replacement can you tell me what that hose is called
- jreed
That hose (#5) looks like it is described as 1m long. I think it's a hard black plastic tube. It might be an acceptable option to replace that with a length of generic rubber or silicone hose.
- 2605 Views
Last post by legalstuff
- 1862 Views
Last post by shaker_chi
- 847 Views
Last post by misha
- 1380 Views
Last post by zimbodel
- 576 Views
