94 model 850 GLE Auto
Put a new battery in but in a short time the power has been drained out
of the battery. I have replaced the battery but something is still draining
the power out of it. So its not charging....
What do you think is the answer and things to look at to make I replace
what is causing the problem.
** Merry Xmas to all"
850 GLE Charging Problem
- Year and Model: Many Volvos
- Been thanked: 75 times
I'm not sure what the local situation is in Brisbane but we can go to any local auto parts store and they will test the battery and the alternator for free. They, of course, want to sell you a new battery or alternator in the process.
Your problem sounds to me more like a parasitic drain. The most common problem with a parasitic drain is the glove box light not turning off. To test that theory just remove the light and see if things change. Beyond that you need to use an ammeter and start pulling fuses to find the source.
I am jealous, I wish it had just turned summer here.
Armed with an ice scraper and ready to go.
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Perform a voltage drop test to see if you have charging problems or parasitic drain.
Voltage drop test: I suppose that you know what are charging specifications:
-everything from 13.5v-14v with headlights and heating on(digital multimeter at + & - battery terminals).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I have been meaning to check my glovebox light forever now and haven't. I saw this, and it happens to be dark out right now...and guess what? my light was on.
Then while messing around...I found a folded up piece of paper with tape on it that had fallen off. Put it back in place...problem solved. Thanks for reminding me Lee!!!!!!
'07 XC90 V8 AWD
- 2828 Views
Last post by dcarlson12
- 544 Views
Last post by jreed
