1998 S70 GLT Modification Help
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
This topic is in the MVS Volvo Repair Database » Squeaky dash - solution
Zerian101
Year and Model: S70,1998
Post by Zerian101 »
Hey, I have a 1998 S70 GLT (Turbo) it is actually my first car I love it, but I want to make a few modifications for It looks old to me. I want to change the tail lights, head lights. Add some interior and exterior LED lighting, and a few for things, but I have no clue where to start I am not car smart which is why im on this site to gain knowledge, Help me turn my s70 into a car someone wants!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Most of us here would suggest making the mechanical parts of the car work "right" before spending money on anything to make it pretty. Most of this stuff is fairly simple, but bringing the car up to a good "Stage Zero" is what I always suggest to new Volvo owners, especially with a now 12-year-old car.
Find out what maintenance has been done on the car; and/or what may need to be done in the near future to keep it in top running shape. There is no point in having a car that looks good, but doesn't run well.
What Is Stage 0? - click me!
'98 S70 T5
2016 Chevy Cruze Premier
Zerian101
Post by Zerian101 »
I just got a oil change, tire rotation, balancing etc.. I need to get a Air Filter for my Engine should I get a performance one and are these easy to instal ( I like to do things myself but will get help if needed) Also my cigarette lighter/charger input does not work could I need new fuses also or could it be something else?
jblackburn
The K&N filter drops right in; honestly, I did not see much of an improvement with my T5 as I did an old Honda with a similar drop-in filter. The cone kits require a bit of re-working, and honestly I don't see too much of a benefit there either. You can choose to go that route though if you wish. Check out www.ipdusa.com for performance parts for your car.
Check the fuse first; I had a penny stuck in my Buick's that kept blowing the fuse for that until I figured out it was stuck in there. If the fuse is OK, you might need to remove the center console & see if the wiring has been unplugged.
'98 S70 T5
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
Zerian.. here is a link where you can make a "home-made" cold air intake. I did this myslef and it cost me less than 35 bucks total.
https://www.matthewsvolvosite.com/forums ... =5&t=32574
1996 Platinum Edition
