Any one hear of vadis the diagnostics program from Volvo
- hanzbe420
- Year and Model: 2006 s60 2.5T
I am currently downloading this program to hook up my Volvo 855 turbo to my laptop. I am seeing this program is very hard to find and cost allot of money? please let me no if any one heard of it thanks.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Many of us here on the site have installed it & use it to look up repair procedures, parts numbers, etc.
While it can be useful for some things and does specify torques, etc., at best, it is hard to find what you're looking for and the instructions are very mediocre. That's why people on the site here make detailed write-ups for working on various parts of the car. I have never tried to hook my laptop into the car, so I have never tried out those features.
For most of the versions out there, you need to set the system date to June 1, 2004 and reboot your computer before attempting to install it. After that, mount the ISO file using a program like PowerISO to a virtual drive, and then run the setup program directly from there. It takes foreverrrrrrrr to install, but once it does, reset your system date and reboot again before attempting to run.
You will then need to setup a user name to access the information in the program. Make sure you select all options for that profile so that you can access everything.
'98 S70 T5
2016 Chevy Cruze Premier
- hanzbe420
Thanks for the info yea its an ISO file and i got poweriso so ill mount it to a virtual drive and run the install from there on the computer. then i just need to get the data cable obdII to usb i think my dad has one i can use, but i am not sure. O BTW is it compatible with windows 7 ultimate 64 bit edition.
precopster
- Year and Model: Lots
- Been thanked: 128 times
I run Vadis on my Windows XP Pro laptop. It's quite good as a part number finder, and for checking if one model's parts can be used on another, though you'll find so may superceding numbers at the dealer it's a joke. For example the O ring seals for the sump (only two part numbers from memory) have superceded to a kit containing just about every O ring for the whole engine with some paper gaskets of unknown application thrown in for good measure!!
As far as Win 7 64 bit, once you follow jablackburn's instructions you may find you'll have to run it in compatability mode for XP service Pack 3
To do so: right click on the shortcut to the program on your desktop or in the Programs menu, find the target folder (it should highlight the .exe file)
Right click on the .exe file and select the Compatability tab, then under "Compatability mode" heading tick the checkbox and select Windows XP (Service Pack 3) then click OK at the bottom.
You can be the first to let us all know if it works.
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Just to clarify, you will not be able to use the OBD diagnotics portion of VADIS with a generic OBD reader. The part needed for that is around $800+. Basically it will function as a computer-based manual and parts reference, thats all.
Windows 7 is fine, run it in compatibility mode as mentioned.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
jblackburn
I have had it on 2 XP Pro machines. My new laptop has Windows 7 64-bit, but I have not tried to install it. Once you mount the image, you can specify that setup and everything else run in a compatibility mode as mentioned if it does not cooperate.
'98 S70 T5
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I have just checked and found I have been running mine for 3+ years. I didn't need to set the date to load it and I know of other UK users who haven't had to do this.For most of the versions out there, you need to set the system date to June 1, 2004
For some time now the prices on eBayUK have been a lot lower than on the US site and most UK sellers will ship to the US at reasonable rates.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
There is a way to beat the date problem in VADIS. I found and did this and I saved these instructions
- Find file 'C:\info\vvindex\ini\cdinfo.ini' (assuming you installed to C: )
- Go to properties and uncheck the read only box (remember to go back when finished and check the box for read only again)
- Open the file and change the values ”WarningDays=150ExpirationDays=180” to 3600 & 3650 respectively
I changed the values to numbers even higher than 3600 and 3650.
If you installed a version of Vadis and haven't had any problems with expiration it could be the seller did the expiry file changes before making the copies.
- 3340 Views
- 3255 Views
Last post by packetfire
- 675 Views
Last post by Michelle19
- 1127 Views
Last post by difflock54
- 1897 Views
Last post by Georgeandkira
