94 850 non-turb manual 160K
Is there a step by step on changing rear main seal anywhere? Can't find it and would like pictures.
Rear Main Seal on 850
White850Turbo
- Year and Model:
I believe the Haynes manual should give you a rough walk-through. It's basically removal of the transmission and the flywheel and carefully slipping the new part in. I would not suggest you even try to do this job unless you have a lift or a helluva strong back and some muscle to go with it. This is an extremely involved job; Not your typical timing belt or other maintenance item. The dealer charges 15 hours labor for the procedure. A shadetree mechanic friend of mine did the job himself with a lift and it still took him almost 3 days.
- 13 Replies
- 3341 Views
Last post by bjack56
- 11 Replies
- 5660 Views
Last post by wjhandy850
- 1173 Views
Last post by 93Regina
- 2462 Views
Last post by FCPEURO
- 1504 Views
Last post by Botbasher
