what do you think of transmax z gearbox oil
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
jannie 1
Year and Model: 2002 S60 T5
Post by jannie 1 »
I un screw the nut under neath the gearbox and let all the old oil
Run out,I screw up the nut,pul out the dipstick and threw 4liters
Of oil in,the oil is trans max m ,but I ordered trans max z because in south africa they
Its a very good oil,so I wil drive it for 200km and then drain it again
What do you think of the oil
JDS60R
Been thanked: 3 times
Post by JDS60R »
I believe you have made a mistake. That fluid is not the proper rating for your transmission. You need it to meet JWS 3309 spec.
Does the Castrol Trans max Z meet that specification? The online search I did shows it only as dextron fluid and not JWS 3309.
You need to remove the fluid and flush with a fluid that meets JWS 3309 spec.
Retired
JDS60R
Post by JDS60R »
Here is Castrol's spec sheet
Castrol transmax Z spec - does not meet JWS3309.pdf
(294.83 KiB) Downloaded 298 times
Retired
JDS60R
Post by JDS60R »
I do not see Transmax M meeting the spec either.
Transmax E does meet the Toyota 4 spec which is JWS 3309
Retired
JDS60R
Post by JDS60R »
Here is Volvo's fluid requirement chart
Retired
jannie 1
Post by jannie 1 »
Thank you for you're help I wil drain it I ask toyota for that oil but there is no grading on only atv t4
And they use it for land cruisers and thete is no saying if it is sentheti oil,so I don't know what oil to use
I the people here is full of shit
Thank yoi
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You just do one thing after another without researching!
that is the WRONG fluid, now you're going to have to have it FLUSHED out and the proper 3309 fluid put in
RaymanSean
Year and Model: V70 XC, 2001
Post by RaymanSean »
Go to the auto parts store and look for mobil one synthetic transmission fluid, on the back of the bottle make sure it states that it meets JWS 3309. I know it does in the US but who knows in SA. You need to immediately either perform a flush drive and another flush or about 7 Drain and Fill with a trip around the block between each to get all most all of the Transmax M out of transmission.
jjaV70T
Year and Model: V70 2.4T 2003
Post by jjaV70T »
NO, Mobil 3309,or TOYOTA type;Asian Transmission used Toyota Fluid.
..I would drain and then do this 'IMO' run the engine in drive for 3 min. , then do the same again. This is what I would do.drive is 5 mi. 10 km the drain and refill..the tranny It is made in japan,.ALSO can you get a software upgrade ? .S-69Tr
.2003, V-70,. 2.4T, 101,100K..
.1985, 245T,.sold at 280K....
.1974, 145, sold at 250K....
N1ne
Year and Model: 2003 S60 AWD 2.5T
Post by N1ne »
You need to do a drain/fill to get all the fluid out or i promise the problems are coming. What make/year is the car ?? For my 03 S60 AWD GT i Drained 2 quarts threw Radiator.Then replace the 2 qts threw dip stick. Did this 6 times 12 qts. Used Mobil 3309 But Volvo JWS3309 or Toyota t-iv will work just the same. I know that others have used Mobil 1 Syn and other JWS speced fluids but JWS-3309 is NON-SYn fluid and to me why take the chance with something that could be sooo expensive to fix just to save a few $$ using cheaper fluid. Cant go wrong with what Volvo(Asia Warner recommends).
