Mobil 1 oil filters
This topic is in the MVS Volvo Repair Database » Rear wheel drive 740 rims fit on V70?
reds70turbo
Year and Model: 1998 Volvo S70 GLT
Mobil 1 oil filters
Post by reds70turbo »
Anyone have any personal experiences to share?
I've been using Genuine filters for the past 60K but my last oil change a Mobil 1 was used as it was on hand and I didn't realize I didn't have a Genuine one.
I am now hearing decent chatter when I first start the car in the mornings after it sits at least 1 full night. I'm thinking it's the filter as this is new behavior.
I have done my oil pan o rings recently and do not have any other funny symptoms....
Thanks for your input.
1998 S70 GLT - 183K - full of fun stuff and meticulously maintained!
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
I used a Mobil 1 filter (cartridge style) with no problems. They have pretty good reviews around the web, but it's possible it may not be 100% right for your application.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
reds70turbo
Interesting to know, I wonder if your cartridge style Mobil 1 filter is of greater quality or better effectiveness vs. the canister style on my 98.
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
I'm not sure Mobil 1 filter has an internal check valve as the Mann/OEM filter to hold oil pressure to the lifters while starting up.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
reds70turbo
That's mainly what kind of information I'm looking for here. I know Mobil 1 is a very reputable brand of oil and that alot of people use the oil filters. But I'm wondering if the filters have the same check valve quality that the OEM/Genuine ones do...
phat78ta
Year and Model: 94 850 turbo wagon
Post by phat78ta »
confused_al wrote:I'm not sure Mobil 1 filter has a internal check valve as the Mann/OEM filter to hold oil pressure to the lifters while starting up.
:? I'm pretty sure NO oil filter has a "check valve" in it to do this, but I could be wrong. The lifters hold their own pressure with the oil inside the lifter bodies themselves.
As far as the filter goes, any name brand filter will do the same job, filtering contaminants out of the oil. Most of the time, multiple brands of filters are made by the same company, painted different colors and sold in different boxes. Generally, you are buying different name rather that a different product.
Did you change oils as well as the filter? If you switched to a synthetic oil, it may have cleaned out the accumulated gunk that kept the lifters quiet on cold start up. A change of filter brand would not cause this issue.
93 850 GLT sedan 156K
94 850 Turbo 189K
Has thanked: 1848 times
Been thanked: 1710 times
You've answered your own question here! Over several decades and many Volvo's I've only ever used Volvo oil filters as they have a check valve in them to prevent oil leak-down when you turn the engine off (according to Volvo). Especially with the hydraulic lifters it is more important than ever. I have never found an after-market filter that worked as well, and for the small insurance, to me ( a Scot!) it is cheap insurance.
Hopefully once you swap it out all will be quiet!
If someone out there has found a good 'alternative' filter with the same performance, good luck to you, but I still won't change!
Volvo used the same filter for probably near 40 years for good reason, and that is why most of their engines last so long IMO!
reds70turbo
Volvo filters certainly do have a check valve as stated below, unless that is just Volvo talking up their product. I really don't think so due to the fact that once I switch to an aftermarket filter I begin to hear something I haven't ever heard in 60K miles.
Yes, full oil change. I'm a Castrol High Mileage 5w30 guy in the winter but due to WalMart having a limited selection at the time I put in Pennzoil High Mileage 5w30.
I was using Full Synthetic for a while but wasn't happy with the motor noise and went to a "thicker" High Mileage oil afraid that synthetic just wasn't doing my 180K mile powerhouse much good. It is good oil but I feel that the car needs something more appropriate.
I also had my oil pan off changing my o rings a few weeks ago and there wasn't one ounce of sludge. :)
reds70turbo
scot850 wrote:You've answered your own question here! Over several decades and many Volvo's I've only ever used Volvo oil filters as they have a check valve in them to prevent oil leak-down when you turn the engine off (according to Volvo). Especially with the hydraulic lifters it is more important than ever. I have never found an after-market filter that worked as well, and for the small insurance, to me ( a Scot!) it is cheap insurance.
I hear ya, damn it. I wish I had a Volvo filter back when I changed the oil. :cry:
One will be going back in soon, for sure.
confused_al
reds70turbo wrote:I wish I had a Volvo filter back when I changed the oil.
Buy a case of 10 this time (FCP or eEuropatrs), that will last a few years :P . BTW, I heard that Bosch filter is repackaged Mann filter, but never have chance to confirm that. Wondering if any chain stores would carry those.
98 MB ML320
06 V70
95 850 GLT(RIP)
