I posted about a chronic problem with my V70R crusise control. I read everything on the forum. I tested the column switch, the brake pedal switch, and checked the vac. lines under the battery. All was ok, I looked at the cc module, under the fuzes, opened it and damaged the connections to the exterior male plugs. I resoldered them. Results were negative. However, I pulled the module once more and decided to check the soldered connections with an ohm meter. One was open! I resoldered it. Upshot, Cruise control work fine. Praise God.
Note of interest: The ABS module had the same failure, the primary connections to the exterior male plugs failed. Thanks to all of you who put the info on the forum I was able to fix the ABS module myself. Now it looks like the same issued occurred on my cruise control module. I suspect engine compartment temp. is high from the turbo, causing the modules to fail. I wonder if the door lock module located behind the glove box could have the same issue?
My door lock remote fob has been chronic for the last year. I have to push the fob 20 or more times to get it to unlock or lock. I've changed the battery. Since it's chronic, comes and goes, I am going to look at the module behind the glove compartment. Seems like it could be the same issue-failing solder connections or bad circuit board. It seems like if a solid state component fails it should be bad all the time and not chronic, it wouldn't come and go. Where as a broken solder or circuit board connection could be chronic. Anyway, I'll let you know what I find out in a week or so.
George
fixed chronic cruise control
1998 Volvo v70 xc - awd fuel pump Fix
georgegrimm
- Year and Model: 96-960, 98 v70r
- 651 Views
Last post by erikv11
- 17 Replies
- 6494 Views
Last post by ignatz
- 5294 Views
Last post by THeOldMan
- 12 Replies
- 5871 Views
Last post by 1337
- 3555 Views
Last post by precopster
