Can someone tell me how the PTC Nipple is removed from the air intake housing.
Do I have to remove anything else?
What about the vacuum line attached to it?
Volvo V70 AWD SE 2000
Thanks,
PTC Nipple removal and cleaning
PTC Nipple Vacuum Line Routings
Michael Dixon
- Year and Model: V70AWD SE 2000
JRL
- Year and Model: Several
- Been thanked: 16 times
That's just one little piece to the puzzle
If you have a glogged breather you should remove everything, intake etc, install new lines, hoses, nipples and a new breather box
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Remove the lines and pull. Hard.
You'll probably have to take the whole tube out to get it back in, though. As JRL said, it's likely the whole system is clogged up by now.
More reading for you:
https://www.matthewsvolvosite.com/forums ... =1&t=28487
'98 S70 T5
2016 Chevy Cruze Premier
Michael Dixon
Jablackburn,
Thanks, just wanted to clean that up before I did the whole job to see if it cured the smoke in the dipstick problem.
Mike
Mike
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
I had mine apart a few weeks back. I found it was very tight on the intake tube, so I removed the whole assembly first. Once the whole air intake tube is removed, you can carefully pry the rubber flange of the PTC loose, and pop it off the intake tube. Give it a good cleaning, and carefully scrape all the crap out of the inside of that PTC. If it's anything like mine was, it'll be full!
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
Michael Dixon
Renns,
How did it run after you were finished?
renns
It ran fine before and after. I did the job as part of routine PCV maintenance.
- phils94850
- Year and Model: 2009 s60 turbo
Michael... ive cleaned several and as the above members have mentioned usually if the nipple is clogged then the entire pcv system needs replacing. Cleaning the nipple is just a 'temporary" sometimes fix. What exactly are the problem(s) your having. If your getting smoke out of your dipstick then the pcv sys. needs replacing..
1996 Platinum Edition
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Try and do it when its warm...Clean the outer part of the rubber off, then soak it in WD40 or similar. After this it should be malleable enough to take out by bending one way or another.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
DGM
- Year and Model: V70 2.4i 2005
- Been thanked: 3 times
Ideally you have to remove the air intake tube (#17) to throughly clean the PTC. But before doing it you must remove the cripped OEM collar (#9). There is a twist to it.Michael Dixon wrote:Can someone tell me how the PTC Nipple is removed from the air intake housing.
Thanks,
Use a small flat screwdriver and find the end of the ring and pry it off its groves. Then you will be able to remove the air intake. The plastic tubes connected to the PTC are brittles and can be easly broken. Be careful when moving them around.The rest of the procedure was well explained by other member.
The vaccum line is very important. It initiates system draw. Make sure it is well cleaned. Normally the elbow union (#10) is degraded and soft. It should replaced.
This is a quick fix and only a part of the whole solution as already adviced. Good work
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
- 1033 Views
Last post by kahl
- 1319 Views
Last post by 98v70xc206
- 837 Views
Last post by G Martin
- 899 Views
Last post by Sommerfeldt
- 18 Replies
- 7283 Views
