2006 S60 removing climate control panel in passenger compart
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
normf
Year and Model: S60 2006
Post by normf »
I need to access the AC temp sensor in the passenger compartment on my 2006 S60 sedan. How do I remove the plastic cover? Does it just snap out? I'm obviously concerned about breaking it or damaging the surrounding interior trim. What kind of tool do you recommend?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
You posted this THREE times.
Not going to get an answer when you do that!
cdnbluez
Year and Model: 09 C30/98 V70/99 S70
Been thanked: 3 times
Post by cdnbluez »
2007 C30 T5 6 Speed
2005 S40
2006 XC70
2014 Mercedes E350
1996 Corvette Convertible LT4
Previous Volvos:'09 C30 5 speed, '99 S70, '99 S70 5speed, '98 V70 SE, '04 XC70, '01 V70, '02 V70 awd, '97 855, '90 745 Turbo+, '90 745 16v, '89 780 Bertone Turbo+, '86 760 Turbo+, '82 240 GL
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The 05-07 s60 and V70/XC70 have a little difference in how the climate/radio set comes out.
You pull up the panel around the gear lever and you will see two TX25 screws below the lower set of switches in the area uncovered by removing the panel surrounding the gear lever. Remove those and the whole radio and climate set drops a 1/2 inch or so and you pull the whole thing out a bit and disconnect the connectors.
Remove ground for battery first or you risk a ton of codes or worse. The climate control assy and the radio will come out of the plastic carrier. The temp sensor removes from rear of the climate control unit.
normf
Post by normf »
Thanks cdnbluez for posting the instructions and jimmyz for the fine points.
I apologize to those offended by the post appearing 3 times. My mistake, not my intent. I am still new to the sight and made an honest mistake. I tried to delete the extra posts when I realized my error, but couldn't figure it out.
I very much appreciate the insight and advice I have gotten on this sight. You've been a tremendous help.
