02 t6 transmission symptoms to look for
blue02
Year and Model: s80 t6 2002
Post by blue02 »
02 s80t6 91K miles (probably 70K on used transmission installed before I bought it). Runs great, any symptoms I should look for regarding the transmission. also, any advice to give my daughter (who will be the main driver, she does not have a lead foot) on how to keep the turbo from killing the tranny. Great forum thanks
peetek
Year and Model: 2003 s80
Post by peetek »
tell her to put it in nuetral when stopped at lights, that will save tranny
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
No; that will only kill it faster. Same reason all the 01 V70/S60 transmissions have died.
Check the fluid - wipe it on a white paper towel and check the color, maybe do a flush if it looks like it needs it. Aside from that, there's really no tell-tale symptoms unless it shifts hard or seems to slip.
'98 S70 T5
2016 Chevy Cruze Premier
dcarlson12
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by dcarlson12 »
jblackburn: Are you saying that shifting into neutral at lights just makes the valves cycle more than necessary or ?????? i.e. what causes teh 01 V70/S60 trannies to fail?
jblackburn
Yes, you're just shifting parts of the transmission around that only last so many cycles. The AW trannies in the 2001's shifted into neutral every time you come to a stop, and then re-engage when you step on the gas again. The idea was to save a little bit of gas and help the clutch packs last longer, but that wasn't what happened. After about 100,000 miles of doing that (some earlier), solenoids and valve bodies began to fail and the transmissions began dropping like flies.
The GM transmissions just suck because there's so much torque from the T6 engine being put through a poorly-designed transmission. Late-90's American transmission designs were never very good. They were designed for their own cars (Chevy Impala, Pontiac Grand Prix, etc) with much less powerful V6 engines, and it was a poor choice by Volvo to mate them with the T6 engine.
'98 S70 T5
