Has anyone had to replace the suspension on their XC90, specifically with self leveling rear (7 pass)?
I have seen front struts available at ipd or fcp, I think it was in the range of $200-$300 per side, but I haven't seen any rear suspension options, I know I can get them from the dealer but it is probably pretty expensive.
I am thinking about replacing these at around 75K miles (6-12 months) so I am wondering what others have done. So if you have done this what have you used (Bilstein, etc.)? And where did you get them?
Thanks
XC90 suspension replacement
Monroe Struts a Good Choice for Volvos?
05 V70R TiKap (so happy) 91K
05 XC90 2.5T FWD TiBlak 97K
94 850 wagon 2.4 (N/A) 155K (Sold running like a champ)
jimmy57
- Been thanked: 320 times
If you are replacing the Nivomat self-leveling on the rear then there are no options.
You can search around and find them at several shock outlets.
I have replaced Nivomats before when they were still functioning correctly in leveling vehicle and the ride and behavior did not improve on the rear. They are a very sturdy unit and as long as they hold the oil they usually perfrom damping function well for a long long time. Do the front and see if you aren't happy with the result.
- 1037 Views
Last post by precopster
- 12 Replies
- 2792 Views
Last post by RickHaleParker
