TCV line tip, maybe
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Volvos rock3
Year and Model: v70xc, 2002
TCV line tip, maybe
Post by Volvos rock3 »
So I replaced my TCV lines with pretty blue ones from IPD, on our 02 V70XC. I did extensive reading on this forum as well as others before hand. I noticed several posts that stated the OP was having trouble with access to the "red" or compressor line. :?
When I did mine I removed the air intake pipe and then kneeling on the rad support, supporting myself on the strut bar, I could easily reach down and under the turbo and reach this connection point. The hardest part was squeezing the green clip with just my fingers, because you can not get a pliers at it. When I reinstalled the line I did it from the top, replaciing the line, and to get the clip back on, I went under the car with a pair of long needle nose pliers with a 90 degree bend at the end and it was easy breezy. :D
So anyway hope this helps.
1996 850 GLT sdn (deceased)
2002 V70XC 118k
2009 S80 3.2 37k
1998 Chevrolet K1500 84k
1965 Pontiac Lemans convt
2009 Chevrolet Tahoe PPV 2x (work)
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
It definitely does. I ended up doing it from the top and it was not easy.
