I'm hearing an rattle out my passengers window, it sounds like a tin can full of..pieces of tin can. In my old 240 this meant I needed to tack the heat shield (again) or a wheel cover clip was rattling around in there. Ive crawled around banging on heat shields and other suspicious sheet metal to no effect. (This is my first FWD so the drivetrain and suspension is new to me (20 years of 240's, they lost me when they killed off the 245's. Black armband day.) Ideas?
Thanks,
Bob
V70 1999 FWD Non turbo rattle at passenger's front quarter?
- jtp
- Year and Model: 99 v70R
- Has thanked: 11 times
- Been thanked: 10 times
if it happens when you go over bumps, even small ones, it could be your spring seat (the black rubber circles at the top of each suspension column). These are replaced with either xc90 spring seats or a beefed up version from ipd since they always fail. See if you can spin/move laterally that piece. if so it needs to be replaced. They usually lead to clunks as well as rattles when they fail...
99 V70R AWD
Almost 155K Miles
Breaking is how I know it’s working
98 S70NA (sold)
95 850 Turbo Wagon (RIP)
Almost 155K Miles
98 S70NA (sold)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
+1; that's the most common cause. Make sure you have an alignment done afterwards.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
Volvo OEM only - any year XC90 will work.
'98 S70 T5
- 1973 Views
Last post by MadeInJapan
- 693 Views
Last post by cn90
