Dodgy window switches.
mrpainter
- Year and Model: 850 1996
Can anyone tell me exactley how to pull the drivers window switch apart and make it work again. Is it just junk on the contacts under the rocker switch that stops it working. ? Thats on a 1996 850 centre consol switch.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Yep; usually dirt and stuff gets mixed in with the contact grease and they become non-conductive. Scrape everything off, lightly sand the contact points so they no longer appear burned, and then re-apply a little bit of di-electric grease at the contact points.Is it just junk on the contacts under the rocker switch that stops it working. ?
I can't tell you how to get the panel out of an 850; on the S70, it just pries out of the door panel with a flathead screwdriver around the edges.
'98 S70 T5
2016 Chevy Cruze Premier
- 572 Views
Last post by RickHaleParker
- 667 Views
Last post by XavierEduardo99
- 826 Views
Last post by cn90
- 632 Views
Last post by lummert
- 679 Views
Last post by Volvo4251
