Misfiring at full thottle
Engine starts to hesitate and stops pulling. Never experienced this issue ever but also never had as many mods. Wondering fuel injectors fuel pump or spark plugs. No check engine light nothing runs smooth otherwise and idles perfect
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Might be a helpful test to hook up a fuel pressure gauge and get some readings. A bottle of Techron run through your tank wouldn't hurt the injectors, either.
When were your plugs last replaced, what kind are you using, and what's the gap set to?
'98 S70 T5
2016 Chevy Cruze Premier
Thanks for all your responses getting my car back Monday. I will immediately check and change spark plugs if needed first. If everything seems fine will def add some injector cleaner and look into replacement coil. What do you think of the MSD setup or ipds? It is definitely at a high rpm that I am seeing the issue I am very excited to get the intercooler and 2.5 pipework just want to prevent any issues that obviously could cause detonation
Sorry for the late response but issue has been resolved. Changed my cap, rotor and plugs ( auto lite Iradium gap set to .28 ) car is pulling so damn hard though I have to upgrade my FMIC clamps to some HD ones. This site kicks ass!! On order now msd coil and IPD wire set. Maybe I'll treat myself to a chassis dyno soon. So excited to get some actual numbers. Whoo hoo my R will be cruising down the beach this weekend with a huge smile on my face!
JRL
- Year and Model: Several
- Been thanked: 16 times
- 1924 Views
Last post by fisker247
- 25 Replies
- 8890 Views
Last post by DavidsVolvo
- 20 Replies
- 4245 Views
Last post by undflyer
- 33 Replies
- 7449 Views
Last post by styoung94
- 930 Views
Last post by mrscullini
