I have a 95 GLT 850 wagon - nonturbo with an automatic transmission, 98K miles. I just noticed a very hi frequency/pitch whine from the engine. It will rise/fall with rising/falling engine rpm and happens in drive (moving down the road) or in neutral with the car stopped. It seems to be more obvious at lower speeds and may not even exist at hiway speeds.
Could it be the distributor shaft bearing/bushing? Does the tranny have a governor that would cause this? It might even be a normal noise - it's relatively faint - could it be air passing by the t-body? Thanks very much for any help. I haven't had a chance to isolate it yet, but will go under the hood with a stethoscope soon.
When I bought the car, the owner had been running 20-50 weight oil in the car (have no idea why - seems wrong) so I switched back to 10-30 weight. Not sure if this is realted, but don't recall hearing the noise when I recently test drove this vehicle.
subtle, hi-pitched whine (whistle) from engine...???
Mine does this when the car is cold for a few minutes into driving and its only at low to mid rpms. Turns out it's either the serp belt tensioner pulley or the idler pulley(one of the two for the belt). Check those as that's an easy fix.
- 2979 Views
Last post by darrylrobert
- 14 Replies
- 5896 Views
Last post by craywm
- 815 Views
Last post by APCalifornia
- 1594 Views
Last post by Marilyn99
- 901 Views
Last post by 850 LPT
