Power Steering Pump
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
This topic is in the MVS Volvo Repair Database » How To Torque Control Arm Bolts Using A Jack: P80 Volvos
turbotim2
Power Steering Pump
Post by turbotim2 »
I just picked up an 05 S60 2.5T AWD and it sounds like the PS pump is whining awefully loud. The dealer is going to take care of it but I was just wondering if this was a common problem? Thanks!
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
No
What IS common is they leak fluid at the lower hose and if you're just a bit low on fluid it can whine
First check the fluid level and add if necessary
Then look for a PS fluid leak
Again...
PLEASE POST YOUR MILEAGE
turbotim2
Post by turbotim2 »
That was the first thing I checked, no leaks, and full of fluid. It has 80,000 miles and had been regularly serviced at the dealer since new. I will post back when they fix it with the repair.
2004 XC70
turbotim2
Post by turbotim2 »
Turns out it was the alternator. They are replacing it today, hopefully that fixes it.
2004 XC70
