The fan is electric, right?
priapism
- Year and Model: 01 S60
I just did the ETM cleaning--man what a difference. Removed + reinstalled fan. Fan isn't coming on now. But, it's in the low 50s and it took quite a while just to warm up. Is it supposed to run all the time (e.g. is it broken) or does it switch on when needed?
Titan LE : S60 2.4t : 91 325i : Spec E30 #33
JRL
- Year and Model: Several
- Been thanked: 16 times
With a thermostat or when the AC is on
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
...and when the AC is on, only when the pressure transducer indicates around 185 psi or more on the high side.JRL wrote:With a thermostat or when the AC is on
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
priapism
Of course it's electric, that was a dumb question.
We turned the AC on but it was chilly out and it wouldn't blow cold. Never did see the fan turn on. Only one connector on it ya? Put a 180F thermostat in it last week. Drove it to dinner and it never got above 1/2 on the temp gauge, actually went below that a few times.
priapism
Found it...the connector was way down in the bottom of the engine bay, couldn't see it when the fan was installed.
Man, this car has an appetite for torx wrenches. It's eaten two on this job alone!
Brentscrazyptwo
- Year and Model: 2004 S60 2.5T
- Has thanked: 11 times
My 2004 S60 2.5T has the same fan issue. AC won't turn on the radiator fan. Was your solution a connection in the bottom of the engine bay? Thanks!
- 709 Views
Last post by Vancethevolvo
- 1068 Views
Last post by aliff850
- 603 Views
Last post by Guesten
- 1176 Views
- 2479 Views
Last post by benpineapple
