650b electric fan signal missing
Guesten
Year and Model: 2005 Volvo v70
Post by Guesten »
Hello! I have a electric fan that is not working and have never done! I have checked the 60a fuse under electric fuse box in the engine bay, i have voltage in the thick cables that go to the fan. I have tried and hooked up another used fan and its not working either.
I have autocom diagnostic so i can activate the fan manualy. It works on other v70 but not mine.
What should i check???
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Check ground 31/2. It grounds the Fan Control Module and the fan motor.
Active
Past
Guesten
Post by Guesten »
RickHaleParker wrote: 25 Nov 2019, 03:26 Check ground 31/2. It grounds the Fan Control Module and the fan motor.
Hello sir and thanks for your reply! I unbolt the 3 wires, sanded all contact areas and bolted them back again, not any good news. Its the same:( more ideas? And thanks from sweden!!
