1998 S70 blinkers, radio, windows work intermittently
Bnhuntington
- Year and Model: 1998 S70
Intermittent issue when I turn on car my turn signal, radio, and windows all stop working at the same time. If I turn key to run but don't start engine everything works fine, it intermittently occurs only after I start engine. Aim real car novice hoping someone can provide explicit instructions including where to get parts if needed. Thanks!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
+1! Ignition switch!darag2358 wrote:Ignition switch?
'98 S70 T5
2016 Chevy Cruze Premier
- Been thanked: 471 times
Make sure you search ignition switch but the electrical portion of it (L side of steering column):
https://www.matthewsvolvosite.com/forums ... =1&t=34472
bronxnativ
- Year and Model: 96 850 GLT 5 Speed
Yes, ignition switch.
Al
- 1328 Views
Last post by regent
- 535 Views
Last post by GrapeApe123
