2005 S40 High Engine Temp
1996 - 2004 S40
1996 - 2004 V40
gman656
Post by gman656 »
Got a code High Engine Temp, see manual thhis morning. Idle was rough and engine stalled prior to message appearing. The temperature gauge was dead center, so no indication engine was hot. Any ideas?
Juan62
Year and Model: S70 T-5M 1998
Been thanked: 2 times
Post by Juan62 »
Open your hood, run the car until normal temp (if you haven't done so), turn on AC full blast for about 2 minutes. Shut car off, look for any signs of leaks, specifically from the thermostat and theremostat housing, as well as hoses (top/bottom). If you see a leak from the the Temp Sensor unit underneath the theremostat, thats it. But to replace that sensor, go ahead and replace the thermostat w/new gasket. You going to have the drain your coolant as well. might as well replace with new coolant. Oh, make sure your fan is blowing too while the car and AC is running. As you can see, there could be more than one solution to fix one problem. Hope that helps.
98 S70 T5-M Brick for life
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The 2005 S40 has an engine with thermostat and ECT sensor down on the block buried below air cleaner box/ECM housing. This version of the 5 cylinder is reverse coolant flow cooling system engine.
Assuring the coolant level is full and doing the checks suggested is very valid but could require some dis-assembly to perform.
You say you got a code, do you mean just a message center message or were codes readout from car? IF so what is the code?
