I'm looking for some tips on how to replace the J-tube. I got the CEL P0442 and thanks to this forum, found that the J-tube had a crack. I tried for an hour to remove it but no good. Can someone provide some hints on how to remove it.
Also, if someone had it done by the dealer, how much did they charge.
Thanks
J-tube replacement
Juan62
- Year and Model: S70 T-5M 1998
- Been thanked: 2 times
I replaced mine including the other hose. For my S70, I removed the fuel filter bracket, and pushed the fuel filter (towaards the rear) to get access to the two hoses. The hardest and time consuming for me was, removing the factory clamps, the two hoses were simple to pull out and replaced. For your S80, not sure what clamps Volvo decided to use, but mine were the good ol fashion clamps (like the old sardine can with key). Jack the car up a little (enough that you have room to operate) with both tires still touching the ground. You can do this with determination. I just replaced both hoses so I don't have to repeat the process again any time soon. Also, I ordered a new fuel filler cap (Volvo) for good measure from IPD.
98 S70 T5-M Brick for life
- 5067 Views
Last post by JimBee
- 1073 Views
Last post by 01_Nautic_V70
- 1468 Views
Last post by 98v70dad
- 705 Views
- 1253 Views
Last post by JexedM89
