P0240 showed up on my reader but no engine light on. It's strange and it's a bit annoying.
V70
2005
T5
Sent from my HTC Desire using Tapatalk
P0240 anybody had this issue?
I looked into that deeper and first it sound like the MAP sensor but most likely the turbo boost line leaking somewhere so I gonna try a leak test.
By the way anybody know what's the oem boost pressure should be?
I tried with obd2 and shows max 9.2 psi.
JRL
- Year and Model: Several
- Been thanked: 16 times
Not sure on an 05 but a LOT more than that, in the low 'teens
The code refers to the turbo boost pressure circuit range /performance. So ether the pressure sensor failing or the hoses leaking somewhere. I did a leak test on the turbo boost line and discovered a leak which I didn't expect. Now the pressure is a lot better than before. Only one thing I wondering on. The code need to be cleared by CPU after N fault free cycles. How long that can take?
jimmy57
- Been thanked: 320 times
For engine management faults the code clear is typically 40 warm up cycles after the MIL is turned off. That is the process on North American models, I have no idea if that is true for Euro markets. If it is a "pre-set" code where the fault has not occurred on consecutive key on cycles and has not yet turned on the MIL then it will self clear sooner but I don't recall the warm up cycles in that case.
