Turn key in ignition, nothing
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
This problem has been intermittent. Sometimes when I go to start the car, I turn the key and nothing happens. If I hold it there for a few seconds, nothing. Then, and it is *always* like this, the second time I turn the key it starts cranking the engine right away.
The car will do this for like a week then it will go away, then it comes back. Been going on about a month.
I had the battery checked it showed fine, the alternator was just rebuilt. I was wondering if it could be the electrical portion of the switch, that has never been replaced, but there are no other symptoms (e.g. no other, goofy behavior of the car's electrical system).
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Do the dash lights and stuff come on before you turn the key?
We had a car that used to do this - it was a bad ground connection on the main negative cable. Otherwise, it would run fine - it was just when you tried to activate the starter.
'98 S70 T5
2016 Chevy Cruze Premier
Post by erikv11 »
Hmmm thing is I just added a second ground off the battery, when I did the engine swap. I'll recheck the contacts but I have a feeling they are clean.
'06 S60 R, 197k
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
A bad PNP switch can cause the starter not to work as well but it normally shows up in other forms as well like the flashing up arrow. The PNP problems tend to rear their ugly head more in the winter than in the summer.
phat78ta
Year and Model: 94 850 turbo wagon
Post by phat78ta »
Could it be the Ignition switch itself? The electrical part? I know that is a common failure point also.
93 850 GLT sedan 156K
94 850 Turbo 189K
Post by Ozark Lee »
The way to find out which side of the ignition switch the issue is is to use the service starter wire. It sticks out of the wiring harness next to the left hand strut tower. As I recall it is either a red wire with a green stripe or a green wire with a red stripe but it has a connector on the end. Battery voltage to that wire should trigger the starter if the PNP is OK.
If the starter is reliable from that point then look back towards the ignition switch.
headdragon
Year and Model: 98 S70 GLT
Post by headdragon »
Does the key also go all the way around none stop once and awhile.
Post by erikv11 »
The key just turns regularly, moves only to the correct positions and returns normally.
I have not been troubleshooting this because the car is down for some engine work right now. But will get to it ...
'06 S60 R, 197k
