2001 V70 T5 turning key get nothing
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Davell59
Year and Model: 2001 V70 T5
Post by Davell59 »
I have a new battery . Sometimes when I turn key I get nothing . Then will wait sometimes 1 minute ,sometimes 1 hr. Car will miraculously start like nothing wrong . Showing no codes at mechanic . Thought it was the immobilizer but no codes came up. Could key cause this? Frustrated to no end. Car runs great otherwise. Just started happening. Am going to try using the newer key. Any suggestions much appreciated.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Not the key.
Check/replace starter relay. Get a 2nd person to tell you if the starter relay clicks with fuse cover off. If it clicks and doesn't start replace it, if no start again go further along the route to the starter solenoid. A test light to check for voltage/load is indispensable.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
As above, maybe see this www.youtube.com/watch?v=mhNawwOORiM
Maybe also an ignition barrel issue
Year and Model: 2004 V70 2.5T
Been thanked: 467 times
Post by cn90 »
Maybe it is bad ignition switch (electrical portion).
Tons of DIYs on repair (clean the contacts) vs replace it ($55).
