2004 S80 A/C Blower
copleyvolvo
- Year and Model: 2004
Blower only occasionally comes on-should I replace blower motor and resistor?
I have the same problem with a 2001 S80. 288,886 miles on it. I have the A/C blower turned all the way on, and only switch the A/C on when it blows. If it stops blowing, then I turn the A/C button off (as a precaution). I noticed that it will blow more in the summer months using the A/C than in the winter when the heater is needed. If the motor continues to blow long enough (sometimes stays on when the car is shut off) after I turn the car off, then when I restart it - there is a good possibility that the whole console goes dark. The only thing that works in the center is the cigarette lighters - nothing else. I tried to diagnose a little further - just a word of caution - (only I can't remember which fuse) do NOT pull out the fuse, as it will mess up the air bags and you will get that error message each time - and the air bags will not work. (Sorry I can't remember which fuse).
Didn't mean to take over - just trying to see if yours is having similar issues.
- 46 Replies
- 13032 Views
Last post by 93Regina
- 764 Views
Last post by Synergychaz
- 1150 Views
Last post by oragex
- 602 Views
Last post by BobbyC777
- 740 Views
Last post by xc90surfer3
