Hi all,
My 2004 V70 fan/blower gets very noisy and vibrates (dash and steering wheel) quite a bit above the #4 setting on the fan dial. The dealer suggested a cabin air filter change (which I did) and 'cleanout' (I stuck the shopvac hose up there as far as I could)...the noise and vibration continue. Any other ideas, or do you think this is a matter of swapping out the blower motor?
Thanks!
2004 V70 Noisy and vibrating Fan/Blower
'87 740 wagon--liked it, but sold because it held the highest value
'98 V90--liked it, but died on the freeway due to an overheat
'93 850 sedan--absolutely loved this car while overseas
'01 XC70--never really keen on it; totaled after it found a ditch
'04 V70 (x2)--love them; our current daily drivers
JRL
- Year and Model: Several
- Been thanked: 16 times
Yes
They go bad
They go bad
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
The only moment my blower was noisy and vibrating, is when the wired ceramic element around the rotor broke in pieces when I tried to remove the rotor to lube the bearings. If that's you case, you are in for a new motor (no need to purchase it with the resistor)
- 14 Replies
- 4989 Views
Last post by bichinavolvo
- 26 Replies
- 1921 Views
Last post by MoVolvos
- 33 Replies
- 7390 Views
Last post by styoung94
- 1639 Views
Last post by Jlerro
- 11 Replies
- 4593 Views
Last post by dim28
